It is currently Wed Nov 22, 2017 4:38 pm
Post new topic Reply to topic  [ 7 posts ]
 Post subject: Rev Limiter at 6000
PostPosted: Thu May 04, 2017 9:33 pm
Hi,
just taken a risk and bought a 2006 S2 SC which hits the rev limiter at 6000. Engine pulls strongly and smooth to that point then the limiter cuts in. I could just drive around using revs below but that would be no fun so any suggestions as to what I should look at first. Am told it was uprated to 255 cup shortly after new and had a new block 3000m ago, I reckon it hasn't rev'd past 6000 since. Anything obvious I should look at first?
Cheers.
 Post subject: Re: Rev Limiter at 6000
PostPosted: Tue May 16, 2017 7:59 am
If the engine temp is not high enough, the limiter pulls in. Wait until 80 deg. + before you push the throttle.
PostPosted: Fri May 19, 2017 3:41 pm
thanks for the tip. Temp is generally 94-96 but perhaps it is a sender issue. Do you know where the temp sender is that sends the message to the cam or how the message is passed through the ECU? I'll just work through all the possible issues one by one with the easiest first.
PostPosted: Sat Jul 29, 2017 11:43 am
Oil pressure can also stop the cam from engaging.
PostPosted: Sat Jul 29, 2017 7:16 pm
Also Check fuse R6 7.5 amp in the engine bay.
PostPosted: Sat Aug 12, 2017 5:26 pm
Dean, thanks for your suggestions.
There are no indications of a problem with the oil pressure and I checked fuse R6 and it is fine.
I have further thoughts - When the engine was replaced a non-cat exhaust was fitted so the MIL is showing orange, any thoughts as to if this is tricking the ECU into thinking that there is an engine problem and so cutting back the power? Do you know if this is possible?
PostPosted: Mon Aug 14, 2017 10:06 pm
Hi Charlies
I would read the mil codes, there can be more than one stored.
If there's no cat you may need a mil eliminator loom, but this will not stop the cam from engaging.
On my old NA exige when cold the limit was 6000 with red led on.
There's a guide here, but I think your fault is a sensor issue.
http://www.toyotaownersclub.com/forums/ ... ng-thread/
Hope you get it sorted.
Users browsing this forum: No registered users and 1 guest
