It is currently Sat Oct 21, 2017 6:52 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Sun Oct 08, 2017 11:03 am
The forum has been very quiet recently. So I'm going to post some more progress of my project.
I let the engine run for the first time. After changing almost all sensors, the cambelt, coolant fluid, etc. I was quite happy when it started without serious trouble.
I really like the eager sound of the VHPD engine when idling :-P . The small Odyssey 680 battery does its job very well and seems to be powerful enough even when starting multiple times.
First job was to synchronize the two pairs throttle bodies. Using a Synchrometer this would have been an easy task if the balancing screw hadn't been to short to adjust the two pairs. I bought a new longer M5 screw and a suitable spring that prevents the screw from getting loose. After shortening the screw and the spring some millimetres I was able to balance throttle bodies. The engine runs much smoother now.
PostPosted: Sun Oct 08, 2017 11:23 am
I re-installed the boot floor by bonding and riveting it in. I replaced the original rivet fixing of the heatshields by rivnuts so the heatshield may be remived in the future.
I have no idea how the thick upper heatshield made of thick foam could be installed on the folded boot floor. It should stay there just held by a single stripe of double sided tape.
After cutting it into two pieces along one bend I hope it will stay there just with the use of double sided tape.
PostPosted: Sun Oct 08, 2017 11:39 am
The seats have been re-installed after freshening them up a little. A new set of Schroth ASM harnesses were used as the old ones looked a bit tatty.
To keep the original appearance I let the local shoe maker transfer the 'Safety Devices' sew on sticker from the old belts to the new ones.
After reading some reports of Exiges on fire I decided to install a FEV gas fire extinguisher.
For the first time the cabin looked how it should be and I spent at least 10 minutes strapped down in the driver seat enjoying it :-).
PostPosted: Sun Oct 08, 2017 12:20 pm
That does all look very lovely 8-)
PostPosted: Sun Oct 08, 2017 6:03 pm
Doesn't it look great, well done Klaus. Mega.
_________________
#498
PostPosted: Sun Oct 08, 2017 6:48 pm
Thank you for the kind words.
One of the smaller jobs was to replace the missing connector for the stack speed sensor. Thankfully John (aka JDS here on exiges.com) could provide a new connector :thumbup:.
After connecting it to a new speed sensor the speedometer was back alive (at least the needle moved when I turned the wheel in the air).
Users browsing this forum: No registered users and 3 guests
