It is currently Mon Feb 19, 2018 6:09 am
Post new topic Reply to topic  [ 4 posts ]
PostPosted: Mon Mar 20, 2017 7:56 am
I started to remove the steering rack.
2007 S2 with Sona rack (to be repaired with parts from Dave)
Followed instructions on seloc but
I'm a bit stuck at the point where I'm supposed to disconnect the lower UJ from the rack spline.
I've loosened the UJ clamp screw, and I have removed the 4 chassis-rack screws.
Is there a special trick to get the UJ off the spline?
/Michael
PostPosted: Mon Mar 20, 2017 1:02 pm
Take the bolt right out of the uj where it attatches to the rack. Then its a bit of a wiggle and it should come loose. Theyre proper tight and awkward to get at though.
PostPosted: Mon Mar 20, 2017 7:38 pm
They bloody are but it does come out.
_________________
#498
PostPosted: Wed Mar 22, 2017 7:43 pm
It's out !
Once out it's quite obvious why I coild not get the UJ off the rack.
I do feel more than a bit :oops:
The play found in the offside turned out to NOT be a worn out inner joint.
Some very clever person (likely the same one who has done something even worse with car - but more on that later in another topic) probably adjusted toe by unscrewing the entire toe link rod from the rack !
Here's a movie of the thing.
https://drive.google.com/file/d/0B5F6hsAAjExMdGVrWlNxYV85cW8/view?usp=sharing
Pictures High Res
https://drive.google.com/file/d/0B5F6hsAAjExMcWJfMF9Pby1hWkU/view?usp=sharing
https://drive.google.com/file/d/0B5F6hsAAjExMRXNzTk9GQWlGWFk/view?usp=sharing
https://drive.google.com/file/d/0B5F6hsAAjExMdjd1cEk3SW54aHc/view?usp=sharing
File comment: The joints are leaking a little bit of grease. Something I should be concerned about?
File comment: A fair bit of play
Users browsing this forum: No registered users and 1 guest
cron
