It is currently Mon Sep 24, 2018 4:22 pm
Post new topic Reply to topic  [ 11 posts ]  Go to page Previous  1, 2
PostPosted: Sun Feb 18, 2018 4:48 pm
Ohlins damper lengths & spring rates
Easiest way to tell is to simply measure the dampers (measurements are centre of the top end eye to centre of bottom end eye)
Exige 240 & pp
Front 337mm/57nm
Rear 414mm/74nm
Exige Cup 260 -
Front 327mm/80nm
Rear 404mm/105nm
2-11 std ( i think the 211 has shorter length wishbones too)
Front 316mm/80nm
Rear 384mm/105nm
Picture shows 260 cup springs with locking collars set at std ride height for 240 springs. The cup springs are shorter both front and rear.
To convert a set of 240 shocks to 260 spec it's valves, shock length & springs. I need to get my shock lengths sorted, so i can run a lower ride height.
Users browsing this forum: No registered users and 2 guests
