andybond
Contact:
Re: Exige S2 with added supercharger
Post by andybond » Mon Nov 19, 2018 9:28 pm
661 wrote:The 211 boxes fail at 270 bhp
I had the SSC 3rd 4th and FD. JDS cooler (LSD/Redline/long 6th etc)
The soft stuff in the box (syncos etc ) must be considered consumables and rebuild every 6-7000 miles is not unreasonable if you use the car as a track car and drive to the track.
The new gears were great and didn't ever look like the weak point. (300 hp at the hubs)
I am new to the game - 211 ? Is that the c64 6spd?
Any idea what torque level kills them? Some are saying 190. some 200ibft.
The cooler seems to be key.
What gearbox/transmission fluid did you use?
seriouslylotus
Contact:
Post by seriouslylotus » Tue Nov 20, 2018 8:33 am
211 is the open track car lotus made, uses the same Toyota supplied engine and box as Elise and Exige S2 so yes a C64
ade
Post by ade » Tue Nov 20, 2018 12:09 pm
Mechanical sympathy will help, but as said, if you track it, it will break! Watch my video, no curbs, it broke at peak torque in 3rd......
andybond
Contact:
Post by andybond » Tue Nov 20, 2018 9:28 pm
This isnt fair. Nothing else is allowed to break!
I will be especially cheesed off as I am but a small % higher than the 260 exige torque wise!
jfk
Post by jfk » Tue Nov 20, 2018 9:42 pm
Good job you haven't fitted a 2.8 pulley .
Things get even more expensive then... I got through 3 clutches in short succession !
Exedy , helix and standard.
But the SSC gearset and quaife diff were bulletproof :-)
andybond
Contact:
Post by andybond » Tue Nov 20, 2018 10:23 pm
jfk wrote:Good job you haven't fitted a 2.8 pulley .
Phew!
Just a 74mm pulley!
ade
Post by ade » Tue Nov 20, 2018 11:13 pm
andybond wrote:This isnt fair. Nothing else is allowed to break!
don't forget that gearbox was designed for 190hp and no torque at all,
the teeth on 3rd and 4th are very narrow add the flex in the shaft and expansion of the gearbox from heat, means the skinny teeth don't mesh completely and hey presto no teeth on 3rd gear,
fix it before it does break ;)
andybond
Contact:
Post by andybond » Wed Nov 21, 2018 10:35 am
but the same box was also in the 260 exige? Is that right ?
ade
Post by ade » Wed Nov 21, 2018 10:53 am
Yes, all S2 Exige use exactly the same gearbox NA 220 240 260
only difference is some will have an LSD
240hp + cars also came with a better clutch, again the standard clutch was designed for 190hp and no torque, mine spun out on a dyno run. My car was originally a 220hp car and that gave up at 260hp
andybond
Contact:
Post by andybond » Wed Nov 21, 2018 10:56 am
I have LSD , and uprated clutch.
I feel I might be sat infront of a ticking timebomb :)
This could be fun
