It is currently Sat Nov 17, 2018 9:45 am
Post new topic Reply to topic  [ 7 posts ]
Author Message
PostPosted: Wed Dec 19, 2012 12:47 pm
Offline
Can anyone supply a adaptor to connect a -10 on the oulet/inlet (bottom conection) of the oil filter housing. I have been supplied one by Earls but it bottoms out and the washer is moving and I'm sure it won't seal.
Thanks for any help.
Top
 Profile
PostPosted: Wed Dec 19, 2012 1:46 pm
Offline
All the ones I have tried have done the same. We normally machine off a thread at a time, until the washer touches the housing. Not had one leak yet.
Top
 Profile
PostPosted: Wed Dec 19, 2012 8:33 pm
Offline
Thanks for that, do you manage to get a socket on it or do you manage to get a spanner on it? It doesn't seem to be the easiest thing to do up and undo.
Top
 Profile
PostPosted: Wed Dec 19, 2012 8:57 pm
Offline
No, they're a complete pain in the bum!!
Have just about managed to get a socket on them in the past, think they are 27mm from memory, as I have a really thin walled one just for them.
Top
 Profile
PostPosted: Thu Dec 20, 2012 2:36 am
Offline
And whilst you are at it, don't get too heavy handed unscrewing and re-fitting the oil filter. The housing has a design weak spot that can lead to a hairline crack that then allows an annoying drip of oil! On my first Exige S1, I eventually had to eventually remove the entire assembly and had the crack welded which strengthened it and stopped the leak!
Wonder if anyone else has had this problem?
Cheers,
Pete. :)
Top
 Profile
PostPosted: Thu Dec 20, 2012 9:30 am
Offline
ditto with the thinkauto top hats, stripped the threads off one when it touched the block before sealed. Had to machine 3mm off the end to get it to seat.
Top
 Profile
PostPosted: Thu Dec 20, 2012 7:08 pm
Offline
Thank to everyone for your help, every job on this car seems to be a pain so far but it's getting there.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
