Page 12 of 12
Re: 2004 Exige S2...
Posted: Mon Jun 29, 2020 1:50 pm
by Fonzey
The Hornet wrote:
Mon Jun 29, 2020 12:34 pm
Car booked in for late July to have EMU Black fitted and tuned.. will of course let you know results after that is done..
Nice, where are you booked in?
Posted: Mon Jun 29, 2020 1:53 pm
by The Hornet
Hangar 111 - they did the 280s kit I have, so are probably best placed to get the best setup...
I have also emailed ECUMaster to see if they can give some pointers on helping me sort my fuel readings to the GARW dash
Posted: Mon Jun 29, 2020 2:36 pm
by Fonzey
Good stuff, H111 are a bit far for me but looking to get into RRR Engineering for my install, looking like August at the earliest atm.
Posted: Mon Jun 29, 2020 2:48 pm
by matt447
The guys at RRR Engineering were great when I got mine fitted :)
Posted: Mon Jun 29, 2020 2:50 pm
by Fonzey
Good news! Have you discussed T/C with them at all? I believe the EMU has a couple of options for it, one using the ABS speed sensors that came on all S2's and one using an aftermarket speed sensor for some more gucci functionality.
Posted: Mon Jun 29, 2020 2:55 pm
by matt447
I've not discussed Traction Control with them because it's not on my radar.... :/ Lets not forget I'm driving the Naturally Aspirated version, haha ;) I only need it if I'm driving like a plonker in the rain ;) With smooth inputs mine is pretty planted.
I'm pretty sure the software shows it down the side bar and you can just turn it on with the parameters you choose. Again, I've not looked in too much depth because mine is far less likely to break loose than if I'd got some kind of forced induction...
Posted: Mon Jun 29, 2020 3:03 pm
by Fonzey
Yeah fair enough, my current T/C is always disabled on track anyway otherwise it just kicks in every time the inside rear tries spinning up - can't drive hard with it at all. I believe the EMU module for it has got options for variable slip though which might make it a bit more useful in wet conditions so it's something I may look into, just as a bit of a safety net.
Posted: Mon Jun 29, 2020 3:11 pm
by matt447
In which case.... I may have a play when I get chance! :) I could definitely use a 'safety net' at Cadwell Park in the wet, lol! ;)
Posted: Mon Jun 29, 2020 3:22 pm
by andybond
You dont need T/C In a boosted car either TBH unless you drive with lead boots..
