Can I put my intercooler here?
s-express
Post by s-express » Wed Dec 26, 2018 4:50 pm
Ok, so I'm in the middle or a (more or less) total rebuild. Front end done, now on to engine and box removal for overhaul. One thing I'm not happy about is intercooler position, apart from the fact that there's nowhere for the air to escape to (I will be cutting out numberplate area for this), the intercooler is also not placed very well so I would assume what little airflow does get to it, then finds it easier to go around the side of it rather than through it!
So thinking of relocating to the rear of the clam, as high and as wide and as deep an intercooler as I can make fit (as seen by the red lines). Also considering ducting all the way from the rather large side scoop, over the intercooler and then sealed nicely against the rear of the clam.
Anyone any thoughts on this?
Did consider going the charge cooled route but I reckon this will be simpler and at least as effective.
Alex
S1 Exige 036 Audi powered
evo_ufo
Re: Can I put my intercooler here?
Post by evo_ufo » Sat Jan 12, 2019 3:59 pm
Provided you have a shroud and air routed to it don't see why not. That's basically where it is on the 211 so would suggest that you seek out some pictures of that install.
s-express
Post by s-express » Sun Jan 13, 2019 6:05 pm
Thanks yes was going to duct into and out of it. Didn't realise the 211 had it there, will do some research - many thanks :-)
Teverill
Post by Teverill » Fri Jun 07, 2019 3:54 pm
That is exactly what I have done, will find some pictures when I get home and hopefully that can help
